Romanian Translation
Am tradus EssentialPIM în română. Traducerea curentă este pentru pentru EPIM 5.8. Am lăsat şi traducerile mai vechi, în caz că ele folosesc cuiva. Ultima versiune a filei de limbă poate fi găsită la adresa de mai jos:
http://muntealb.orgfree.com/Traduceri/t ... sentialPIM
Fila de limbă este de asemenea ataşată la acest mesaj.
I have translated EssentialPIM in romanian. The current translation is for EPIM 5.8. I have also kept the older translations, in case someone needs them. The latest version of the language file can be found at the address specified above. It is also attached to this message.
- EssentialPIM-4.5-RO.zip
- (20.24 KiB) Downloaded 583 times
- EssentialPIM-5.03-RO.zip
- (26.06 KiB) Downloaded 525 times
- EssentialPIM-5.57-RO.zip
- (28.85 KiB) Downloaded 478 times
- EssentialPIM-5.8-RO.zip
- (24.87 KiB) Downloaded 467 times
Thanks very much for the translation! Let us know if you require a EPIM Pro license key for further work on it
For the moment I don't need a Pro license, I have tested the translation with the trial version and the free version is enough for day-to-day use. Probably this will not change with the next version of EPIM, but if I will ever need a Pro license for testing the translation I will ask you for it at that time.
Thanks, published it on the web site for now: http://www.essentialpim.com/index.php?r ... &pr=lfiles.
Re: Romanian Translation
Traducerea a fost actualizată pentru EssentialPIM versiunea 2.8
The translation has been updated for EssentialPIM version 2.8
Thank you muntealb.
Traducerea a fost actualizată pentru EssentialPIM versiunea 3.0 RC3
The translation has been updated for EssentialPIM version 3.0 RC3
Traducerea a fost actualizată pentru EssentialPIM versiunea 3.02
The translation has been updated for EssentialPIM version 3.02
Traducerea a fost actualizată pentru EssentialPIM versiunea 3.03
The translation has been updated for EssentialPIM version 3.03
Traducerea a fost actualizată pentru EssentialPIM versiunea 3.04
The translation has been updated for EssentialPIM version 3.04
Traducerea a fost actualizată pentru EssentialPIM versiunea 3.1
The translation has been updated for EssentialPIM version 3.1
