Today Button in Mini Calendar for Direct Back from other months to Today
AJ
Has thanked: 50 times
Been thanked: 8 times
Post by AJ »
hi admin,
the today button in mini calendar would be great to get quick back to actual month and date after using other.
its very efficient.
maybe you can add it soon, the position were above wk number before weekday.
i mean all month calendars, left and right sidebar but on right only in the first month if have added more.
thx
Helps Make EPIM Great/No1!
Has thanked: 1639 times
Been thanked: 1160 times
Re: Today Button in Mini Calendar for Direct Back from other months to Today
Did you know you can click on the month name to quickly return to the current month with today's date visible?
AJ
Post by AJ »
thx, nice but doesnt select today to have auto the right preview under mini calendar.
hope to improve to auto select today or add the button.
thx
If you're in the Calendar module, you can always click the Today button to instantly return to today's date.
AJ
Post by AJ »
ok, the idea was to have it in actual area of action, the today button is farest of right mini calendar.
i try to make it intuitive and efficient, maybe rethink it.
thx
