how to put all done tasks under other keeping order?
AJ
Has thanked: 50 times
Been thanked: 8 times
Post by AJ »
how to put all done tasks under other keeping actual order?
almost 100tasks total so search a method to auto sort out done tasks to list bottom.
not deleting as some for reuse, all should stay in list. some disabled for better overview.
its kinda too pro for my level, so how to do it?
i think it works somehow
thx
Helps Make EPIM Great/No1!
Has thanked: 1639 times
Been thanked: 1160 times
Re: how to put all done tasks under other keeping order?
If grouping is not enabled for tasks, the completed ones should remain in their current position within the list.
AJ
Post by AJ »
if sort by prio would my order be keeped by using . or _?
what is the sorting order/rules?
i know you can use the mentioned signs, pls give me the sorting rule or order, i'm not into it.
thx
I'm not entirely sure I understand your request. Could you please rephrase it or provide more details about it?
AJ
Post by AJ »
i would sort by priority and to keep forced 2nd level sorting rule.
what is sorting rule for the names?
you can use extra signs and . - _ etc.
whats the sorting rule besides numbers and letters?
Symbols go first, then numbers and finally letters. I hope this answers your question.
AJ
Post by AJ »
yes, both sorting options/hierarchy maked it.
only use mentioned symbols so no need to know symbol hierarchy.
thx
