Have to refresh screen after exit Beta Testers
- VictorParkerPIM
- Has thanked: 9 times
- Been thanked: 70 times
In the forum:
When I exit Beta Testers I always have to refresh screen to be able to logout.
This don't seem intended.
Win11 Pro Ver. 24H2 (OS Build 26100.3915) 64-bit, 32GB Ram, C:\500gb M.2 SSD, D:\8TB, 4Km, EpimPro Life 12.2.1 b.1042
- Has thanked: 1639 times
- Been thanked: 1160 times
Re: Have to refresh screen after exit Beta Testers
I'm not entirely sure what you're referring to when you say: "When I exit Beta Testers" - could you please clarify? Please also note, that if the issue is related to the forum software (phpBB), it's likely that we'll need to wait for an update or patch from the phpBB team to resolve it.
- VictorParkerPIM
You have to login to do anything in the beta section of the forum.
Going back to the main part of the forum it does not show that I'm still loged-in until F5 refresh is done.
This is a minor problem and it's ok to wait, it's been this way for a long time.
Thanks for the quick replies.
