The horizontal line.
- VictorParkerPIM
- Has thanked: 9 times
- Been thanked: 70 times
When we click the "\" in the toolbar to make a horizontal line the cursor is placed at the end of the line.
Would you place the cursor at the start of the next line, unless there's a reason to leave it as is.
I know if you start typing at the end of the line the type is placed at the right place.
If the cursor is at the far right everyone is going to press enter before starting typing.
This will save one key click every time the horizontal line is inserted.
I know this is very minor but it does not look right leaving the cursor at the end of the line.
- Has thanked: 1639 times
- Been thanked: 1160 times
Re: The horizontal line.
Thanks for the suggestion! I think we'll implement the default behavior you recommended in one of the upcoming EPIM builds.
- VictorParkerPIM
- VictorParkerPIM
The fix was quick and great, Thanks.admin wrote: Mon Mar 31, 2025 6:43 pm Thanks for the suggestion! I think we'll implement the default behavior you recommended in one of the upcoming EPIM builds.
Win11 Pro Ver. 24H2 (OS Build 26100.3775) 64-bit, 32GB Ram, 500gb M.2 SSD, 4Km, EPIMPro Life 12.2.0 b.1041
