Using Kanban. Manual, Dependencies and Idea.
AJ
Has thanked: 50 times
Been thanked: 7 times
Post by AJ »
hi all, admin,
i dont get the working and dependencies between other modules and kanban.
i just got the feeling i have no idea how it works together, the modules together with kanban, and think the kanban module should be possible to open in seperate window to keep a appt module aside for quick eye on appt.
a look in the help shows only a screenshot, so i feel huge need to see a video tutorial to get it or find it out.
tips very welcome!
thx!
Helps Make EPIM Great/No1!
DG
Beta Team
Has thanked: 29 times
Been thanked: 42 times
Re: Using Kanban. Manual, Dependencies and Idea.
Post by DG »
Kanban is a way to organize and view tasks. I think there is no connection with other modules.
AJ
Post by AJ »
DG wrote: Fri Mar 28, 2025 2:00 pm Kanban is a way to organize and view tasks. I think there is no connection with other modules.
i mean for example tasks as appointments and other way, which i dont understand well.
there are also some other questions.
AJ
Post by AJ »
i seem oversaw first the appt list on the right bottom, as i need it on the top left.
but try first to come out with that.
