Add a "beep" when a search is not found.
- VictorParkerPIM
- Has thanked: 9 times
- Been thanked: 70 times
I'm doing a search in the upper right search field in Notes, when I type a character that the search does not find,
all of the characters in the search field turn red.
I don't always look at the search field while I'm typing, please have a "beep" when the characters turn red.
Sometimes I have typed a couple of words after the search was not found.
- ecsaltz
- Has thanked: 34 times
- Been thanked: 91 times
Re: Add a "beep" when a search is not found.
+1VictorParkerPIM wrote: Sat Mar 22, 2025 3:22 am I'm doing a search in the upper right search field in Notes, when I type a character that the search does not find,
I think this should be a feature in every module of EPIM that has any type of search entry field.
Cell phone: AT&T FirstNet Samsung Galaxy Z-Fold 6, Android 14 - linked with Garmin Fenix 6 Pro wrist watch and Fitbit Sense wrist watch.
- Has thanked: 1639 times
- Been thanked: 1160 times
That's an interesting idea, thanks for sharing it!
- ecsaltz
At the danger of making this too complicated such that it deters implementation, I would suggest the following for consideration, in the Options menu:
1. Turn the beep on or off (globally). There may be times and users who don't want it.
2. Have the ability to select a standard beep sound in Windows, or maybe upload a sound file for the purpose. For some, if could be a "fun" sound!
Maybe experiment with this concept in the current Beta if it is not too complicated to implement?
- VictorParkerPIM
ecsaltz, Admin,
Thanks for the favorable reception of the Beep Idea. I was pleased to hear your comments.
good idea.ecsaltz wrote: Sat Mar 22, 2025 3:34 pmAt the danger of making this too complicated such that it deters implementation, I would suggest the following for consideration, in the Options menu:
by try to test search in actual stable i noticed you cant use search in epimtoday or change toolbar by right click!
but good idea.
some may want to set and/or window prompt if no results, like you get feedback from system by errors.
some, like me.
Helps Make EPIM Great/No1!
