Calendar Week CW in epimTODAY, after Monday!
hi admin,
i need often kw number and use mostly epimtoday.
pls add in epimtoday (xy) or (cwXY) in one spacer distance, after each monday!
example: Monday (12) or Monday (cw12)
() would be better then []
cw is calendarweek, but would be more work as translation needed, so one example with and one without.
thx
thx
Helps Make EPIM Great/No1!
