Other themes
- Has thanked: 31 times
- Been thanked: 13 times
Other themes
In addition to light and dark, it would be nice to have a theme that is not so dark (more of a grey tone). I find the dark one too dark, although that is of course individual.
Re: Other themes
i think you can adjust that by custom colors or was it all other apps i used newly.
i think one can adjust windows theme and let the apps follow, if programmed setting.
we should concentrate on more important, like digital desktop clock as control center, which is posted in forum.
hope it helps, the adjust possibilities.
Helps Make EPIM Great/No1!
Re: Other themes
Thank you for the suggestion. We do have this option in our roadmap for future versions of EPIM.
Re: Other themes
i would appriciate a setting 'follow system settings' /colors /themes or design!admin wrote: Mon Feb 10, 2025 11:31 am Thank you for the suggestion. We do have this option in our roadmap for future versions of EPIM.
this makes all apps be consistent with choosed system design!
if not possible jet. have it allready in some apps.
one could propably just put a selection button and let follow the system settings.
propably quicker realisable.
but not so important!
many thanx!
Re: Other themes
hi admin,
if you need setting idea for dark them, i agree with the user recommended here the notepad++ settings...
"Most probably, the best setting is bckgr RGB: 57, 57, 57 (0-255); letters RGB: 227, 227, 227."
i find the white text quite much to bright.
i would propably use the setting follow system theme/settings.
the above could be good standard dark theme.
