stuck on version 12.1.2 build 1026
- Has thanked: 32 times
- Been thanked: 20 times
I understand that version 12.1.3 has arrived. I've used 2 test versions of updated? version 12.1.2. When I go to check for updates, it tells me that none are available. Is this because build 1026 is the same as version 12.1.3 or a bug in the checking process for the interim builds?
Should I sit tight, download 12.1.3 and install and will it upgrade 12.1.2 build 1026?
- Has thanked: 1589 times
- Been thanked: 1085 times
Re: stuck on version 12.1.2 build 1026
As mentioned in the news on our website (EssentialPIM 12.1.3 Release), the 12.1.3 update is being rolled out in stages. If you haven’t received it yet, it should reach you within the next few days. Hope this answers your question. Thanks.
