Markdown
- Has thanked: 1591 times
- Been thanked: 1086 times
Re: Markdown
In what context would the availability of this feature be personally useful for you? Which modules would you like it to be integrated into?
Re: Markdown
The idea is to enable quick information entry. The advantage of Markdown is the ability to input information that can later be utilized through queries. What I really miss in EssentialPIM Pro is the ease of creating dashboards.admin wrote: Mon Jan 27, 2025 1:17 pm In what context would the availability of this feature be personally useful for you? Which modules would you like it to be integrated into?
For example, I would like to have an overview of all recorded tasks or easily retrieve information from all entries. The tags already available in EssentialPIM Pro are helpful, but the advantage of Markdown lies in the ability and ease of adding tags directly to specific pieces of information.
Markdown goes beyond simple searching. It allows counting and querying across all entered information.
At a minimum, I would like to have Markdown functionality available for notes and tasks.
Thank you for your follow-up.
Re: Markdown
Understood and thank you for providing the detailed context. We’ll include this suggestion in our to-do list for future consideration.
