Short Cut for Canned Responses
DanFelix
Has thanked: 44 times
Been thanked: 8 times
Post by DanFelix »
I would like to suggest the addition of keystroke shortcuts for the insertion of Canned Responses. While in the Mail Module, the use of a Ctrl+1 to insert the associated canned response. Maybe Ctrl+1 through Ctrl+5 for five different Canned Responses.
Has thanked: 1569 times
Been thanked: 1070 times
Re: Short Cut for Canned Responses
Thank you for the suggestion! We will add a feature that allows you to set up shortcuts for canned responses.
DanFelix
Post by DanFelix »
Thank you. Much appreciated.
