better presentation/display of holidays! ideas
AJ
Has thanked: 31 times
Been thanked: 5 times
Post by AJ »
i have no idea how to show now holidays nice way but have ideas how it should be.
holidays should be displayed this way or by user setting:
(EDIT: epim today in red (font) between date and week day, over the appointments!)
other views: red background
there are some holidays which are not really free, like 24.12 or 31.12., you can shop but shorter.
they should be possible to show as other holidays category, with other colors, lighter red.
the holiday color should be customizable, as some may want green as symbol for free time, however.
i just started putting holidays by hand and have no idea how to let them show in epimToday between date and weekday, which makes very much sense.
propably you have to implement it (first).
thanx
Helps Make EPIM Great!
SEE MY IDEAS FOR EPIM search.php?keywords=&terms=all&author=a ... mit=Search
Has thanked: 1569 times
Been thanked: 1070 times
Re: better presentation/display of holidays! ideas
You can already assign a customized category to holidays or create a separate calendar dedicated to them.
a8907433
Been thanked: 178 times
Post by a8907433 »
This is very individual. For me it is quite perfect as it is- I even not use "Today" at all. For me calendar is suficcient. I have some different coloured categories, for notes, birthdays, hollidays.... I even use different categories for birthdays of "important" and "not so important" people for me.
@admin: I suggest aggain, to have different types of categories for emails and calendar! For example I have to use RED for: important birthdays in calendar- AND for important mails!
AJ
Post by AJ »
admin wrote: Thu Dec 26, 2024 10:47 am You can already assign a customized category to holidays or create a separate calendar dedicated to them.
i have no idea of that, but however.
(EDIT: @ADMIN: you seem to overseen the first chapter of my post!)
the holiday should appear in epim/today in the middle between date and weekday over the appointments of the day.
do you mean it works now somehow or do i missunderstood it?
thanx
a8907433, you can create two separate red categories if that's what you need. However, I'm not sure we understand the reason for having separate categories for each EPIM module. Could you explain your reasoning?
AJ, I'm not quite sure what you mean by "the holiday should appear in epim/today in the middle between date and weekday over the appointments of the day." Could you create a mockup image to illustrate your idea? This would help us understand it better.
a8907433
Post by a8907433 »
Well, that is easy to understand I think: In Emailmodule you can have for example 5 different colours and they stand for "important", "very important", "login data in email", "Eric" and "Susan". In Calendar you may want to have also 5 different colours for: "important", "very important", "Holliday", "birthday" and "personal".
I worked in emails with tags before categories were introduced. Then came categories and I found them usefull for categorising notes in calendar (in appointments). Then I found it usefull to also have categories in mail. Now I have for example category red (holiday in calendar) and also the same red category "holiday" for Susan......
Categories are very usefull for distinguishing different items in different modules- but they have different meanings in different modules! I don´t want to have too many colours and there are not as manydifferent "reds" which you can easily distiguish on first sight. So I want to have (for example) the same red category for mail and for calendar, but they should be differentiated some kind... easily distiguished this is the "red category Susan" in mails, or this is the "red category holiday" in calendar!
It´s just because of different needs and meanings in different modules!
I hope this is explained easy....
AJ
Post by AJ »
admin wrote: Fri Dec 27, 2024 10:41 am a8907433, you can create two separate red categories if that's what you need. However, I'm not sure we understand the reason for having separate categories for each EPIM module. Could you explain your reasoning?
hi admin,
it would be this way:
Wednesday New Year 01.01.2025 above the following appointments for the day.
you just put the holidays name between weekday and date so it's better visability!
it should work this way if i create holidays myself, they should be shown there but in english you say also holidays if you take free time at work. i'm on holidays. it could be inconsistent category in english, but now you should really understand where it's to show. hopefully.
a8907433, thanks for the explanation, we will keep your suggestion in mind.
AJ
Post by AJ »
admin wrote: Sun Dec 29, 2024 8:36 am a8907433, thanks for the explanation, we will keep your suggestion in mind.
hi admin,
do you now understand as i wrote how the top line of a day with a holiday should look like?
repeat to be sure; example, new year:
'Wednesday New Year 01.01.2025'
for added holidays as category holiday. not sure how you seperate it in english version from on vacations, which you propably have second category holidays or how? this doesn't affect me, as not engl.
thanx
Thanks for the suggestion, AJ. While there are currently no immediate plans to implement this change, we appreciate your input.
AJ
Post by AJ »
admin wrote: Tue Dec 31, 2024 9:34 am Thanks for the suggestion, AJ. While there are currently no immediate plans to implement this change, we appreciate your input.
hi admin,
because of the bright i canceled the position idea, but
it would make sense to have the days/numbers of 'holidays' in epim/today left side calendars in red font!
example: the 'whole day' and 'new year' should be red font!
consider for feature! keep in mind!
thanx
