Can't create New Task from Calendar?!
AJ
Has thanked: 50 times
Been thanked: 8 times
Post by AJ »
hi epim,
do i oversee something?
I Can't create New Task from Calendar?!
thanx
Helps Make EPIM Great/No1!
DG
Beta Team
Has thanked: 30 times
Been thanked: 43 times
Re: Can't create New Task from Calendar?!
Post by DG »
AJ,
You can create a task while in the Calendar module. Click on the down arrow next to New Appointment, and EPIM offers the option to create a task. See the screenshot.
EPIM Forum - Create task.jpg (9.26 KiB) Viewed 437 times
Hope this helps.
Regards,
DG
