EPIMA PRO 6.0.17 - Name of contact not in Google Messages
- Laurent C.
- Has thanked: 5 times
- Been thanked: 14 times
Hi
I'm using the last Android EPIMA PRO 6.0.17 on my Pixel 7 Pro
When I modify a contact name, the name disappears from Google Messages — not from Google Téléphone
That's a bug !
It makes near impossible to understand contact SMS in Google Messages
Regards
That's a bug !
Regards
EPIM Pro + EPIMA Pro (Android) / W10 Pro 64 bits FR + Office 2019 Pro Plus / Pixel 7 Pro
- Has thanked: 1572 times
- Been thanked: 1074 times
Re: EPIMA PRO 6.0.17 - Name of contact not in Google Messages
Where do you modify contact names – in AEPIM? Do you use the EPIM system account for your contacts?
- Laurent C.
Yes, exactly : the standard of the tool proposed by you in documentation - only modifying contacts in EPIMA
- Laurent C.
It works well with Google Phone App
- Laurent C.
It works not so well with Google Message App
- Laurent C.
It's OK apparently
But, when I modify a name only like "5 Taxi Paris Tour Eiffel", it deletes the name in Message and only the phone number definitely appears =
With a Pixel 7 Pro...
Regards
Regards
- Laurent C.
Not better...
- Laurent C.
admin wrote: Thu Dec 05, 2024 10:02 am Where do you modify contact names – in AEPIM? Do you use the EPIM system account for your contacts?
Do you have any clue ?
- Laurent C.
Gave up...
