I have some issues with the Contacts view.
- When I double click on a contact entry to open it, it takes around 4-5s to open the window. This is way to long.
- Open a contact with the tab "All fields" is very very slow while scrolling the fields down with mousewheel and keyboard, you can see and feel the lag. If I use the mousewheel it takes nearly 20s to reach the bottom. This should be snappy and instantly.
EssentialPIM Pro 12.0.6 (Build 1003) + enough hardware power (32 GB etc.).
