"Select parent note" does not work.
VictorParkerPIM
Has thanked: 9 times
Been thanked: 61 times
Post by VictorParkerPIM »
Often when creating a new Note the "Select parent note" does not work.
Clicking on select parent note, drop-down menu does not appear and sometimes it appears blank.
No error message.
Closing and restarting Epim does not change anything.
Restarting the computer fixes the problem for two or three days.
This has been happening for a few weeks.
Has thanked: 1547 times
Been thanked: 1058 times
Re: "Select parent note" does not work.
Please record a short video demonstrating the issue once it re-appears and then forward it to us. Thank you!
VictorParkerPIM
This is a screen shot when it happened.
Everything works as it should except nothing happens when you click the "select parent note".
The Blank drop-down window hasn't appeared lately. It stays in this condition until the computer is re-started.
Thanks, I hope this helps. This is not an urgent problem.
Win11 Pro Ver. 23H2 (OS Build 22631.3958) 64-bit, 32GB Ram, 500gb M.2 SSD, 4Km, EPIMPro Life 12.0.5
Thank you for sharing the screenshot however, it does not provide much information, unfortunately. Will the text on the "Select parent note" button change its color when you hover your mouse cursor over it?
VictorParkerPIM
Didn't notice any color change when hovered over it.
There was a slight motion of the text "Select parent note" with a mouse click.
I'll watch for a color change the next time it happens.
It just happened!
The text turns blue when hovered over. I also got an error message this time.
Could you please check if you can reproduce the problem on a new test database? We are facing challenges reproducing the issue on our end.
VictorParkerPIM
New Database does not help.
It only happens every two or thee days and sometimes longer.
I've not restarted my computer, if that could be used to help in some way.
Please click the Send button and forward us the complete error log the next time it occurs.
VictorParkerPIM
I did click the send button the last time it happened.
I'll watch for it again.
Thanks for the last few replies, sometimes I get behind with my thanks!
VictorParkerPIM
Win11 Pro Ver. 23H2 (OS Build 22631.4037) 64-bit, 32GB Ram, 500gb M.2 SSD, 4Km, EPIMPro Life 12.0.5
This morning the "Select Parent Note" drop-down does not work. No error message today.
I found that when clicking the bottom right corner edge of the screen it shows the Note Menu behind the Epim Screen.
The drop-down "Select Parent Note" window works on the Desktop view.
When I use Windows+D to show the Desktop view the drop-down "Select Parent Note" window does not work.
Click Here
View on Desktop
View on Epim
Thank you for the update. This appears to be the cause of the issue, we will look into it.
