Would it be possible to automatically place the cursor in the search box when the Tags Explorer window is shown? Even though it would only eliminate reaching for the mouse and clicking once, it would enable the user to begin typing a search string right away. This would be useful when one is busy and working quickly.
Many thanks.
tags explorer search box suggestion
- Has thanked: 1449 times
- Been thanked: 1006 times
Re: tags explorer search box suggestion
I'm afraid this may not be the expected behavior for users.
BTW, did you know that you can use Tab or Shift+Tab to move the cursor between different sections of the dialog window, including the search box?
