Word wrap 'subject' field in task list
DD1
Been thanked: 5 times
Post by DD1 »
Would appreciate the abiity to word wrap the subject field in the task list as it sometimes becomes quite long. I know that I can see the entire line if I hover over it, but better if it wraps. Thank you.
Re: Word wrap 'subject' field in task list
Thanks for the suggestion! I can confirm that it has been recorded in our internal to-do list for implementation in future versions of EPIM.
