Network Setup
robertporter2394
Re: Network Setup
Post by robertporter2394 »
One other suggestion.
It appears the sort [arrange by] function applies to the entire database at the same time. It would be very handy to be able to ONLY sort on a Main Note affecting the sub notes.
Thanks for all your help.
Robert.
Has thanked: 1424 times
Been thanked: 990 times
Re: Network Setup
Noted! Thank you for the suggestion.
robertporter2394
Re: Network Setup
When trying to sort notes using the Arrange By function, all notes are sorted. Is there no way to only sort sub notes under a main note?
Thanks, Robert.
Re: Network Setup
Using only a manual sorting option.
