Cannot create new Takds
Ivy
Been thanked: 4 times
Post by Ivy »
Hello, I'm using EPIM free Portable 11.5.3 and I cannot create new tasks in the desktop application. Creating new tasks in the Android App works fine. After syncing the task is visible and changable in the desktop application. I'm not shure since when this error exists, I think it came with the last update. Can you help me?
Re: Cannot create new Takds
When you attempt to create a task in WinEPIM, are you encountering any error messages?
Ivy
Post by Ivy »
No, there are no messages. Just nothing happens.
Please record a short video demonstrating the problem and attach it to your next post. Thank you!
Ivy
Post by Ivy »
In the video I added a task that is uverdue. It should appear in "Überfällig" but it is nowhere.
When I search the task is also not found, it was not stored. Please see the attached video.
If i choose "store and new" instead of "ok" than the task is also not stored but the window for a new task opens.
VID_20230606_182233[1].mp4
(2.96 MiB) Downloaded 82 times
Thanks for the video. If you now try to search for the newly added task, will it be found? Additionally, please try switching to the second task list to check if the task is present there.
Ivy
Post by Ivy »
Searhing finds nothing and it's also not in the other list. It's just not there.
Ivy
Post by Ivy »
PS: I just found out, that adding a new task by using the field above the tasks works. These tasks are stored.
It's hard to see from the video provided but it appears that the newly created tasks may be getting assigned to a different task list instead of the one that is currently visible.
Ivy
Post by Ivy »
No, the tasks are nowhere, I searched all lists.
But it doesn't matter. Now that I found out, that I can add new tasks in another way, I'm ok with it.
