Notes: Number sequence interpreted as phone number
DoctorBrown
Been thanked: 7 times
Post by DoctorBrown »
In the Notes module on Android, I'm finding that a series of numbers appears to be interpreted as a phone number and a link is automatically generated in the note. I have not found any way to suppress this. In my research, I find that this behavior has been around for at least 2018! It seems that the algorithm to parse a phone number needs a bunch of work. At this time I haven't noticed if this behavior is occurring in other modules.
Is there anything that can be done to suppress this? Here is a screenshot from my Android phone.
Re: Notes: Number sequence interpreted as phone number
You can click on Menu->Settings and disable the "Auto-conversion of text to link" option.
DoctorBrown
Great! Found it. Thank you.
