11.5.2 - External Images in Mail
Locked
gschuze
Been thanked: 6 times
Post by gschuze »
I just loads 11.5.2 and when I open an email that has images, they show as very smail images all together. I do not see any formatted. I checkd options and I do not have "don't show external images" checked.
gschuze
Re: 11.5.2 - External Images in Mail
Post by gschuze »
OK further checking and the images are returned to normal if I check "Vew Zoom Reset. Is there a global setting for this since it only seems to work for each email individually.
This setting is intended to work on a global level, restarting your PC may help resolve the problem.
gschuze
Post by gschuze »
OK, well, in EPIM.ini file under Mail VIEW was set to 0. I changed it to 1 and now all my emails are readable and zoomed in like they were before.
george
The parameter you mentioned is responsible for setting the layout in Mail. In this case, you changed it from Classic (0) to Wide (1). Typically, this setting should not have any impact on the zoom setting in mail.
gschuze
Post by gschuze »
OK I set it back to 0. How do I set zoom globally? I do not want to zoom for each of my emails.
george
There is already a topic dedicated to the issue you mentioned. Let's continue our discussion there to address and resolve the matter:
https://www.essentialpim.com/forum/view ... hp?t=37954
Locked
