Schedule a task monthly. Move to Friday or Monday if it falls on a weekend.
A challenge/example. I schedule a task to fall monthly on the 20th of every month (This could be any date). If the 20th falls on the weekend, I would like the option for it to automatically either move to Friday or Monday. Not on the weekend. I know of no other software that has this ability. Yes, I know I can let it fall late, or check float, but am curious if such an option as I described exists.
Thank You
Thank You
Re: Schedule a task monthly. Move to Friday or Monday if it falls on a weekend.
Thank you for your suggestion. We will definitely consider adding your suggestion to our internal to-do list for future versions of EssentialPIM.
- Has thanked: 2 times
- Been thanked: 63 times
Hello all,
In this case, I figure out that if the monthly scheduled task falls on a...
1. Saturday, it will be moved to the previous Friday.
2. Sunday, it will be moved to the next Monday.
NormTheStorm
Win10 Home Version 22H2 (OS Build 19045.5737) 64-bit, 8 GB RAM, EPIM Pro Life 12.2 (Build 1034)
