Remove local calendar?
Is it possible to remove the local calendar, or a least hide it from any calendar view? I only use a synchronised Outlook calendar, but then every time I try and set a date it defaults to the local calendar, and I have to remember to scroll down to the one I want. It's a constant irritation. If I try to delete the local calendar it simply gets restored. If I set it as read only the program just creates another local calendar. At the very least is it possible to set my Outlook calendar as the default?
- Has thanked: 1418 times
Re: Remove local calendar?
What's your EPIM version number? Once the local calendar(s) are deleted, they should not normally reappear.
Would you mind recording a short video demonstrating the problem? We have not been able to replicate the issue on our end, and seeing the problem firsthand may help us identify the cause.
Hi - short video attached - nothing sensitive on it so I'm happy to do so. I've realised it happens with a further step. If you delete the local calendar, and then try to create a new calendar entry that's when it reappears, as you'll see in the clip. I'm using the current up to date version of W11 if that makes any difference.
- Recording 2023-05-03 075232.mp4
- (8.48 MiB) Downloaded 63 times
Thanks for the video. To prevent new calendars from being created under the Local Calendars account, you can right-click on the Birthdays calendar and select "Delete". Alternatively, you can select a calendar under the Office 365 account on the left-hand side, and new events will be created under that selected calendar.
Sadly it won't let me delete the Birthdays calendar (see screenshot)
- epim.png (21.72 KiB) Viewed 658 times
Will the Delete option for the Birthdays calendar become available, if you add a new local calendar?
