Auto Reply
Auto Reply
Tried to look for an Auto Reply feature but not having a lot of luck. Can anybody point me in the right direction ?
- PeCe
- Has thanked: 101 times
- Been thanked: 348 times
Re: Auto Reply
As far as I know and can find in the translation file of EPIM such a feature does not exist.
So it could be a new suggestion for the developers.
I assume you will use it like an out-of-the-office reply, telling people when you will reply/be back etc.
So as an suggestion for the developers it could be.
Create an option to set an auto-reply for a fixed time period, with the option to sent this reply only to people in the contact list or to sent the auto-reply to all senders.
- Has thanked: 32 times
- Been thanked: 21 times
Re: Auto Reply
I've always done autoreplies at the server level, never in the client. Did you want an autoreply or were you actually looking for filtering and acting on incoming emails. I'd noticed you'd had an idea to delete incoming pdf attachments using an autoreply feature which seemed odd to me.
