Make more comfortable fields sorting in tables
- Allekz
- Has thanked: 8 times
- Been thanked: 16 times
When working on Contacts, Tasks, and Calendar table mode, it would be much better if I could move the fields before and after each other (up and down, in the Customize dialog box) it there were a button for that between the fileds availabe and the piked ones, like many other software. Otherwise the only way to move them is actually by dragging each field to right or left, which is some difficult, specially when I have added many new custom fields. I'm enclosing an image with the possible solution. Please!
- menu.png (17.28 KiB) Viewed 412 times
- Has thanked: 1412 times
Re: Make more comfortable fields sorting in tables
That's an interesting suggestion and shouldn't be hard to implement. Will surely take it into account. Thanks!
