I often use the tabs within a note. Due to my structure, I move certain tabs into different folders. Since you can only move one tab at a time, it takes a long time.
Hence the idea of being able to select several tabs.
Greetings
Multiple selection note tab
- Has thanked: 1418 times
Re: Multiple selection note tab
Thanks, noted!
