Waiting for authorization
- Been thanked: 3 times
Re: Waiting for authorization
OK, if I did this right, video is attached showing the "waiting for authorization" and screen "choose account" web page
Didn't record trying and failing to minimize EPIM.
- EPIM.mp4
- (1.2 MiB) Downloaded 61 times
Thanks, so what if you try to authorize, will the message appear again later?
Authorize what? That is my problem. Authorize all emails in EPIM? Authorize the email I used to buy EPIM? Authorize all gmail emails even if they're not in EPIM?
If there's no Google sync setup in your database, I assume the request is for one of your email accounts. Unfortunately it's impossible to tell how many you have and which one of them is the gmail's one. And whether all the added email accounts work as intended at the moment?
Logged out of all emails whether associated with EPIM or not. Logged in to all of them.
Good news? "authorization" popup stopped. Bad news? Only for a few minutes. Now it's back.
And don't forget . . . the Minimize icon for EPIM (the '_' in upper right) doesn't work. It works for all other apps.
What do you mean you logged out of all emails? Where did you do that? How many email accounts have you added into EPIM? How many of them are Gmail ones? Is there synchronization of any other data with Google?
I have 4 accounts from suddenlink.net and one gmail I access through EPIM. 5 other gmail accounts used by family only in Thunderbird.
I went in to EPIM and gmail and logged out of all email accounts, whether they are accessed through EPIM or not.
Logged back in to only those accounts accessed by EPIM. Still get "waiting for authorization"
I notice each EPIM account has "STMP oauth" under "Outgoing services." Does it matter which one is selected?
We're only interested in the Gmail account you have in EPIM. How did you logged out of that account? Where did you do that? Is there synchronization of any other data with Google in EPIM?
I suggest you to remove the Gmail account you have in EPIM and then add it back. In this case the problem will be gone.
Remember, with frequency, I get a new tab popup in my browser every few minutes listing only gmail accounts. It is from that web page I logged out of all gmail accounts.
FWIW, I'm logged in to Google calendar through 2 of the emails.
Would appreciate if you answer all my questions above. Without the answers we will not be able to move further.
Only one gmail acct setup in EPIM. Remember, often I get a popup listing emails I must sign in to to make EPIM happy. It is in that web site I've ben logging in/out. After your repsponse, I went to EPIM>accounts. Remove and added the one gmail account.
Only other thing associated with Snyc are the calendar in two emails. Those have been working well.
Since removing/adding the gmail account, I get quite a few popups. Listed below.
"Sync in progress. DNS resolve Error. Do you want to abort
"Sync appointments. 1.1 403 Forbidden
"Error registering the following Global Shortcuts
I am unable to Minimize (_) or Close (X) EPIM using the icons in upper left. Have to use END TASK
1. Forward us a screenshot with the first error message.
2. Forward us the sync log file for the second error.
3. That's for your info, you can disable the prompt.
see attached
- GoogleSync_2023_02_22_09_17_03.log
- (7.13 KiB) Downloaded 79 times
- GoogleSync_2023_02_22_09_17_03-1.log
- (9.45 KiB) Downloaded 74 times
