ernsthaftes Problem: Ich kann in den Terminkalender keine neuen Termine eintragen.
Wenn ich das Formular ausfüllen und auf "OK" oder "Speichern&Neu" klicke, erhalte ich folgende Fehlermeldung:
validation error for column "TASKUSERDATA"."IDUSER", value "*** null ***".
Die generierte Fehlermeldung per Mail:
Exception log with detailed tech info. Generated on 30.01.2023 14:39.
Application title: jb.EPIM - EssentialPIM
Application file: C:\Program Files (x86)\EssentialPIM\EssentialPIM.exe
Application: EssentialPIM 11.2.3 19.01.2023
Exception message: validation error for column "TASKUSERDATA"."IDUSER", value "*** null ***".
Exception address: 0077DE64
Main thread ID = 2088
Exception thread ID = 2088
Object Logs:
14:31:13.763 SetViewMode OK
14:31:13.539 SetViewMode 1
14:31:11.030 DBOpen OK
14:31:10.601 SetViewMode OK
14:31:10.375 SetViewMode 0
14:31:10.085 DBOpen
14:38:58.614 TaskDialog_1 Panel3 TitleEd
14:38:55.105 MainForm FormPan FormPan2 TasksForm TablePan MonthViewMP
14:38:10.606 TaskDialog_1 Panel3 TitleEd
14:38:08.613 ExceptionDialog OkBtn
14:38:03.148 TaskDialog_1 Panel3 TitleEd
14:31:47.882 MainForm FormPan FormPan2 TasksForm TablePan MonthViewMP
14:31:46.865 TaskDialog Panel3 TitleEd
14:31:46.380 ExceptionDialog OkBtn
14:31:33.856 ExceptionDialog TextMemo
14:31:30.364 ExceptionDialog OkBtn
Exception stack
Stack list, generated 30.01.2023 14:39
[0077DE5F] IB.IBDataBaseError (Line 420, "IB.pas" + 39)
[0079EEF6] IBDatabase.TIBDatabase.Call (Line 649, "IBDatabase.pas" + 24)
[007A1B84] IBDatabase.TIBTransaction.Call (Line 1670, "IBDatabase.pas" +
Memory: 16250; free 9195
Display: 2560x1080 pixels, 32 bpp, 96 PPI
PrevExceptions:
14:31:46.422 validation error for column "TASKUSERDATA"."IDUSER", value "*** null ***"
14:38:10.525 validation error for column "TASKUSERDATA"."IDUSER", value "*** null ***"
Updates: 1
Last update: 30.01.2023
Keine neuen Termineinträge möglich
- Has thanked: 1419 times
Re: Keine neuen Termineinträge möglich
Please do the following:
1. make a copy of your database file
2. open the created copy with EPIM and delete all the data from it
3. optimize the database, exit from EPIM
4. archive the file it and forward to us (you can send me a PM here in the forum or use our general support email address: support@essentialpim.com)
Thanks!
Thanks!
