Check for update doesnot present description
poet-man
Has thanked: 13 times
Been thanked: 44 times
Post by poet-man »
Hi there,
when checking for updates (using 11.2.1), program presented the description window, but empty.
I downloaded 11.2.2 from homepage and everything was ok after installation.
So why could the window possibly have been empty?
Re: Check for update doesnot present description
When did you initially check for updates?
poet-man
Post by poet-man »
Right before my posting
DG
Beta Team
Has thanked: 29 times
Been thanked: 42 times
Post by DG »
I had the same problem when I checked for updates. The dialog to download the update appears, but it's blank.
Will check it out, thanks for the report!
lorymax
Been thanked: 9 times
Post by lorymax »
It happened to me too more than once, but I didn't pay attention to it and searched the Version History on the site
poet-man
Post by poet-man »
Me too ;);)
Marc Brigitta
Been thanked: 4 times
Post by Marc Brigitta »
I have the same problem here.
It should have been fixed for the latest 11.2.3 version release.
lorymax
Post by lorymax »
I just installed EPIM 11.7 Pro and this problem occurs again. Everything else seems OK
lorymax
Post by lorymax »
I forgot the screenshot
Which version of EPIM were you updating from? Additionally, what is the interface language of your EPIM?
lorymax
Post by lorymax »
I updated 11.6.6 to 11.7 with Italian interface.
But this morning the problem no longer occurs. Now the usual "no updates available" window appears
That's expected since you're already on the latest version, which is 11.7 at the moment.
