sync problem
Nanulie
Has thanked: 7 times
Re: sync problem
Post by Nanulie »
I got the same problem. Deinstall Win-EPim and Android-Epim only works once, after that the same problem as before.
How may I install an earlier (5th??) version of android-epim?
If you got any solution, please let me know.
Thanks, Nina
Has thanked: 1411 times
Been thanked: 984 times
Re: sync problem
Previous AEPIM versions are available here: https://essentialpim.zendesk.com/hc/en- ... sentialPIM
Nanulie
Re: sync problem
Post by Nanulie »
admin wrote: Sat Feb 25, 2023 7:07 am Previous AEPIM versions are available here: https://essentialpim.zendesk.com/hc/en- ... sentialPIM
how may I get the pro android versions?
Re: sync problem
By upgrading to Pro?
