Sync error synchronization HTTP/1.1 404 sind two weeks
I'm using the newest EssentialPim Pro Version.
There, I have been syncing two Nextcloud Account for many months now. Some days ago it started to show for one account a synchronization HTTP/1.1 404 error, each time syncing.
I can send the log also, but don't want to do this in this open forum.
I'm not sure if it started as I upgraded to the newest version.
- Has thanked: 1639 times
- Been thanked: 1160 times
Re: Sync error synchronization HTTP/1.1 404 sind two weeks
Please check if you're able to login to NextCloud using your web browser as the error means there's no required file on the service anymore. If all is ok on the web, forward me the log fie via PM here in the forum. Thanks!
