Appears gray and cannot be clicked on, according to the attached image!
In addition, EssenrialPIM Pro Business often hangs and has to be terminated with the task manager on the computer.
In the help file, as in the attached file, it says "adding_task", but it cannot be used with me in the programs.
I see it is 32 bit version but my PC is 64 bit version.
Maybe it has something to do with it?
PS. Icon in taskbar does not show the programs logo, according to the attached file?
Create sibling task Add as Child or Add as Sibling option does not work
- fel_underuppgifter.jpg (12.93 KiB) Viewed 2191 times
- svarar_inte.jpg (7.02 KiB) Viewed 2191 times
- ikon.jpg (9.99 KiB) Viewed 2180 times
Re: Create sibling task Add as Child or Add as Sibling option does not work
Hello
Have you watched this?
Is the error only with me or is this with others as well?
Can someone Create sibling task Add as Child or Add as Sibling options?
It doesn't work with me anyway?
Please make sure you first select any task in order for the "add as child" and "add as sibling" actions to work.
It does not help.
According to attached files, I have tried both selecting the task and the group for the tasks but the sibling task Add as Child or Add as Sibling option is still gray ie. it is not possible to click on them.
It does not work in kanban and plan view.
It only works in three view for task!
That's how it should be.
