We would like to announce the Release Candidate version of EssentialPIM 11.2. Here's the list of new features that you will find in the new version:
Translation of email messages (settings are available in Tools->Options->Mail->Translation)
Flag email messages to remind you to follow up with them
Support of multiple accounts for tasks
Customize buttons on the main toolbar (right click on the toolbar to select this option)
Ability to set up default reminders for calendars (individually or in general)
Automatically assign categories to certain emails through message rules
More precise weather forecast from local weather providers (USA and Germany)
Option to not strikethrough completed appointments and tasks
UI improvements for the Options dialog window
Ability to export only selected items from calendar
Downloads (you can also update automatically if you're on the Beta update channel that can be set up in Tools->Options->General): EssentialPIM Pro (Installer and Portable) EssentialPIM Free (Installer and Portable) Note, please keep in mind that since this is not the final release version, some issues are still possible with it.
Mail Module, Flag emails: I would like to have the flag on the left side, somewhere between "priority" and "tags"- or an adjustable order. At the moment it is on the very right side of my (somewhat smaller) screen.
a8907433, you mean the column, not the Follow Up button on the toolbar? If so, you can click on the column's name and move it into any position among the visible columns. Hope that's what you were looking for.
English:
Can you place 3 calendars under each other where the middle one is the current month, the top one the previous month and the bottom one the next month. You can, but EPIM will not remember this option if you close and restart. Would be a very welcome addition than manually adding the calendars each time.
Dutch: (for Peter Tak)
Kun je 3 kalenders onder elkaar plaatsen waarbij de middelste de lopende maand is, de bovenste de vorige maand en de onderste de komende maand.
Dit kan, maar deze optie onthoud EPIM niet als je alsluit en opnieuw opstart. Zou een zeer welkome aanvulling zijn dan telkens handmatig de kalenders toe te voegen.
Will there be another option to collapse and expand the button bar on the left? Picture with the text. Like in version 7,8 and 9. With today's large screens, there is no excuse for saving screen space.
epim knoppenbalk nieuw.JPG (11.2 KiB) Viewed 4553 times
admin wrote: ↑Thu Dec 22, 2022 12:50 pm
Hello All,
[*]Customize buttons on the main toolbar (right click on the toolbar to select this option)
Your feedback is greately appreciated!
Hallo Admin,
die buttons der Haupt Toolbar im Bereich EMail werden beim Klick auf eine Mail ohne Text angezeigt obwohl vorher der Text mit Icon angezeigt wurde. Das ist aus meiner Sicht so nicht sinnvoll. Ich sollte einstellen können Icon mit Text oder nur Icon (Hide button lables). Es werden die Labels versteckt obwohl nicht angehakt.
