Wrong categories after sync with EPIM for Android v6.0.9!
Hi there,
after the update to EPIM for Android from v6.0.7 to v6.0.9 and a sync from my EPIM for Windows (v11.0.4 Pro) via WiFi some calendar entries on both devices showed wrong categories! In fact it was a real mess, as hundreds of calendar entries were affected on my main database on my PC, so I had to restore my backup from the day before, losing some changes. I switched the sync to "one way (EPIM -> Android)" immediately in order not to mess it up again and tried it with a different phone (where I haven't installed this update yet) and a freshly created calendar entry. The result:
With v6.0.7 it worked as it should (otherwise I would have noticed it before). After the update to v6.0.9, however, another freshly created calendar entry showed a wrong category on the Android device. So both Android devices (1x Android 12, 1x Android 9) showed this behaviour after the update.
lk
lk
- Has thanked: 1412 times
Re: Wrong categories after sync with EPIM for Android v6.0.9!
Could you please forward us the log file? Would the same problem happen with the newly created category, for instance? If so, please also mention a list of steps so that we could reproduce the problem on our side. Thanks!
- Has thanked: 5 times
- Been thanked: 2 times
Sounds similar to this:
https://www.essentialpim.com/forum/view ... hp?t=37480
Peter
Indeed, it looks very similar to the problem I described here, and I also noticed that some categories are shown twice in the list.pmj wrote: ↑Tue Dec 06, 2022 2:25 am Sounds similar to this:
lk
Please manually adjust (rename) the categories on either of the sides (WinEPIM or Android EPIM), then start synchronization and all should be back to normal afterwards.
Now I uninstalled EPIM for Android (thus removing all data including the categories), reinstalled it, deleted the sync in Windows, reinstalled the sync, configured to "One way: Windows -> Android") and resynced. Now some calendar entries show a different category. Tried the same procedure again: Now some calendar entries show a wrong category. So the behaviour is even inconsistent.
Even worse: The category order on my EPIM for Windows is totally garbled (although all calendar entries show the correct categories here).
What a mess!
lk
What a mess!
lk
Next test:
lk
- Corrected the category order in EPIM for Windows manually
- Uninstalled EPIM for Android
- Reinstalled EPIM for Android, version 6.0.7 (!)
- Resynced (one way from Windows to Android)
lk
Did you try to rename the categories? You can rename them, save and then rename back. Renamed categories will change their last modified date and thus should be resynced in correct order.
For me - this worked for the first category I changed (at WEPIM). Recent events in that category are now correctly categorized at AEPIM.
But for the second category I changed (for caution, I did them separately) it changed all the older appointments in that category to another category at AEPIM.
I've re-synched several times - no change.
Same results on both AEPIM devices
Peter
Will the newly created events end up with the correct second category? And could you please attach a list of categories from WinEPIM and from AEPIM so that we could see their present state? Thanks.
In the category that was fully corrected after renaming and synching, newly-created events are properly categorized at AEPIM.
In the category that wasn't corrected after renaming and synching, newly-created events are properly categorized at AEPIM. But events created after the problem arose, but before re-naming, are still wrongly categorized.
I'll PM the log in our private conversion, with the category list, etc.
Peter
I've just "submitted" 2 PMs. Although they reported as "sent", they're both still in my Outbox, and they're not in my Sent messages.
Is that correct behaviour?
Peter
Here's the answer, from 2018!
https://www.phpbb.com/community/viewtop ... p=15046451
You'd think phpbb would fix the software to show unread / read rather than outbox / sent ...Messages in the outbox are pms that have been posted but not yet opened, once opened they go to sent messages.
Peter
I see you forwarded us a screenshot with the list of categories from WinEPIM. Please do the same for the list of categories you currently have in AEPIM.
As for your question about phpbb - I wouldn't think they see it as a problem that requires fixing.
here the prob is similar but different:
* ok: events WITH categories will be synched correctly between WEPim and new AEPim installation 6.0.10
* ok: all events with NO category on AEPim will be synched correctly as no category to WEPim
* BUT: all events with NO category on WEPim will become category IMPORTANT at AEPim
That's strange.
That's strange.
