Reccuring Event will not be deleted
poet-man
Has thanked: 10 times
Been thanked: 31 times
Post by poet-man »
Hi there,
using 6.09, I have a problem, which might even be there with earlier versions.
I have a recurring event, which I want to delete. It was created some time ago.
Tabbing on delete, EPIM of course asks me, what I want to delete. I choose "current event and all future reccurances".
As a result EPIM will delete current event only!
Trying this with another recurring event, this will be the same.
Can anybody confirm?
Has thanked: 1411 times
Been thanked: 984 times
Re: Reccuring Event will not be deleted
We're unable to reproduce this. If you choose another option, like "The entire series" when deleting recurring event, will it make any difference?
poet-man
Post by poet-man »
@admin
No it does not make any difference
Please make a short video demonstrating how it works on your side with a new test recurring event, will check it out. Thanks!
poet-man
Post by poet-man »
You're right ... new recurring events are not effected. Old ones ARE!
No difference in creation process.
So possibly a change in program somewhen?
It could be.. Will analyze a part of the app that's responsible for the feature. Thanks!
poet-man
Post by poet-man »
Thanks for checking.
Meanwhile I have deleted all recurring events, which was fairly easy, as all those events ended at end of year, so this should "solve" the problem.
