Reminder on the lock screen
marmegint
Post by marmegint »
Hi there,
Notifications will appear on the lock screen even if it is disabled in the settings.
(Settings/Reminder ringtone and vibration/Special/Do not display any notifications on the lock screen: No notifications should appear)
What do I do wrong?
(Sony Xperia 1, Android 9, AEPIM 6.0.8)
Re: Reminder on the lock screen
Works as expected on our side. Will check what could be wrong here, though.
marmegint
Post by marmegint »
For me, this only works properly if I set it separately for each event.
Or what should the events be set to in this case, so that they take over the main setting?
How do you alter the setting for the individual events?
marmegint
Post by marmegint »
Globally
Settings (in AEPIM)/Reminder ringtons and vibration/
The individual events
Settings (in AEPIM)/Reminder ringtons and vibration/EPIM main channel/
Értesítések
Telefonhívás
Thanks for the screenshots, will see what we can do there.
marmegint
Post by marmegint »
Thank you.
