Hi there,
I had to reinstall AEPIM version 6.0.8, and when I restore the backup it won't accept files with encr extension.
Inactive in the file manager, the names of those files are lighter in color.
It doesn't work on 6.0.7 and 6.0.5 either.
(Sony Xperia 1, Android 9)
Encr extension
- Has thanked: 1406 times
- Been thanked: 977 times
Re: Encr extension
Which AEPIM version wat the backup made with?
Re: Encr extension
We're unable to reproduce this. Please share a screenshot from the file manager.
Re: Encr extension
The two files are not the same save, not in either image.
If I rename the file with the encr extension to zip (I just delete the last extension from the end of the file), it will also be active and the file name will also be black (not grey).
But of course it won't be usable.
Starting from the AEPIM settings
(Android's basic file manager) .
In the Solid Explorer
Re: Encr extension
I think we were able to reproduce this issue, thanks. Will address it in the next update.
