I want to have a Note and name it Templates and in that note have several Child notes, named Phone Call:, Doctors Appointment:, ect.
I want search bar to find Templates opened with all child notes available to select one.
Now when I search for Templates the child notes does not appear.
Can it be made to work this way?
And please let the ESC key cancel the search bar.
Using a Note for Templates
- Has thanked: 9 times
- Been thanked: 51 times
- Has thanked: 1424 times
- Been thanked: 990 times
Re: Using a Note for Templates
I'd suggest you to assign a tag to these notes, say Templates. In this case searching by a tag "Templates" you'll be able to see the whole list (child notes included).
About the ESC key - thanks for the suggestion, noted!
