Handy-Sync auf Windows plötzlich nicht mehr möglich
- Has thanked: 1418 times
Re: Handy-Sync auf Windows plötzlich nicht mehr möglich
Did you try to use either of IP addresses for manual connection? Another option is to make sure that Windows Firewall is also disabled, as it could have still been running at a time your G-DATA-Firewall was turned off.
You did try to use both of the IP addresses? If still no go, I'd suggest you to try an alternative option - sync through EPIM Cloud. There's the 14-day trial, so you'll be able to see if it suits your needs. Thanks!
Seems I didn't fully understand this phrase then: "The syncronization saved in win-epim shows strangly the IP-adress 192.168.0.4 - which is not an IP from the hotspot (that's the only connection, that works), but a normal IP from WLAN."
I though EPIM was showing one IP but there was another one.
- Has thanked: 7 times
- Been thanked: 3 times
DEARSSSSS!!!!
I deleted my home-WLAN from android and set up new and JESUS!!! it works. Don't know why, but that doesn't matter
Thanks that much for your help!!!!! :-*
