No 1x1 sync widget on Android 11/12
lk
Has thanked: 39 times
Been thanked: 9 times
Post by lk »
Hi there,
on two of my three Android devices (Android 8 and 9) I can add a 1x1 widget to the home screen. Pressing on it syncs EPIM for Android data immediately with my PC installation. It's this one:
On the Android home screen it looks like this:
However, on my newer Android 12 device, this widget doesn't appear anymore in the list of installable widgets for EPIM. This was also the case when this phone ran under Android 11. Is there a reason for this? Does anyone else use these widgets and can confirm?
(EPIM for Android 6.0.5, but also earlier versions.)
lk
Has thanked: 1411 times
Been thanked: 984 times
Re: No 1x1 sync widget on Android 11/12
We cannot confirm this with the devices running Android 11/12 we have in our possession. Please mention your device make and model, I'm starting to think all these issues you're having are somehow related to the specific OS build by a specific manufacturer.
lk
Post by lk »
Hello there,
it's a Realme 8 Pro (8 GB RAM). When I bought it last year, Android 11 was pre-installed and already at that time the PC sync widget wasn't available. This hasn't changed when the update to Android 12 came in some weeks ago.
Some other EPIM widgets, however, are selectable on this phone. Now I compared the widget list of this phone with the ones on my other devices and found out that all six 1x1 widgets are missing! The other six widgets (with bigger default sizes and resizable) are listed and selectable. Maybe a hint?
lk
lk
Post by lk »
Some days ago the update to Android 13 came in, but the problem remains the same: The 1x1 widgets are still not visible (and thus selectable).
(Am I the only one having this problem on newer Android versions?)
lk
lorymax
Been thanked: 7 times
Post by lorymax »
Same thing on a Xiaomi Redmi Note 12 with Android 14.
Only the "add" widgets are available, the individual buttons are missing.
The individual buttons are shortcuts. It seems that we need to convert them into widgets so that they are accessible on all supported Android versions and devices.
