EssentialPIM 11.1 Release Candidate
Hello All,
Introducing the Release Candidate version of EssentialPIM 11.1. Below you can find a list of changes:
  • Improved the global Sidebar feature: choose what comes first – calendar or tasks, close either of the sections instantly without going through menus, additional horizontal calendars (if width allows), a list of upcoming events for calendars
  • Zoom in/out embedded and attached pictures in emails to their original size
  • Ability to add any number of weather locations (including option to use your current location) and switch between them in Calendar and Today (right click on the weather icon)
  • Introducing rulers in Notes (enable by clicking on View->Ruler)
  • EPIM now remembers last used quick search scope between restarts
  • More compact, better looking text formatting toolbars in Mail and Notes (switch back to the legacy style by right clicking on them, if needed)
  • Change the look of anchor lines in Notes (Tools->Options->Notes, Anchor line properties)
  • You can now easily create duplicate leaves in Notes by using copy-paste
  • Clear all formatting function for notes and email messages
  • Visual indication about how to add files (as attachment, inline or as link) when dragging and dropping them into notes and emails
  • Statuses for notes (public/private, favorite, read-only, etc.) are now displayed on the right for cleaner and more understandable look
  • Improvements related to synchronizations with EPIM Cloud and iCloud
  • Improved import of events from CSV files
  • Fixed issues with sending out mail for some email services
  • Other fixes of known bugs and various improvements
Note, this isn’t the final release version, so some minor issues are still possible with it. Try it at your own discretion.
Downloads:
EssentialPIM Pro (Installer and Portable)
EssentialPIM Free (Installer and Portable)
You should also get this update automatically if you’re on the Beta update channel (change/check in Tools->Options->General).
All comments, bug repots, and suggestions are very much appreciated. Thank you!
Triple S
Been thanked: 7 times
Re: EssentialPIM 11.1 Release Candidate
Post by Triple S »
Drop down box to switch to legacy toolbar has issues with high-dpi settings
Triple S
Post by Triple S »
Font size select also got squished. At least in high dpi environments.
Triple S
Post by Triple S »
Since this is an RC built I decided to take it for a test drive on my daily database and quickly notice a very important issue.
The icons on the right are not solid, so in a real database with lots of long names that scroll off screen they become a mess of unreableness.
In the demo screenshot attached for example it is incredibly hard to tell what is private and what is private + read-only.
And it gets especially bad when you have bold light red and yellow items that are read-only and/or starred. Which I have a lot of since it's a common formatting choice for me.
Thanks, will improve these points before the final release version.
