PRO activation problem
Laurent C.
Has thanked: 4 times
Been thanked: 12 times
Re: PRO activation problem
Post by Laurent C. »
It works — but so weird !!!
EPIM Pro + EPIM Android (AEPIM) / W10 Pro 64 bits FR + Office 2019 Pro Plus
paulvp
Been thanked: 4 times
Post by paulvp »
Hi folks
I've just encountered this problem also - i.e. I previously bought the pro version of AEPIM but this is now not being recognised.
AEPIM version: 6.0.14
Phone: ASUS Zenfone 8, Android version 13
AEPIM Pro purchase date: 23/04/2014
For ADMIN: I'll PM you the order number as per instructions earlier in this thread.
Cheers
Paul.
Laurent C.
eddie_s79 wrote: Mon Aug 28, 2023 11:51 am
lorymax wrote: Mon Aug 28, 2023 11:32 am I too had the same problem recently. The solution is always the same. Install AEPIM 5.8.7 which you can download from the link below. After that update to the latest version from play store.
https://essentialpim.zendesk.com/hc/en- ... sentialPIM
Thank you very much @lorymax.
Additional info (maybe helpful for others): I had also problems getting the EPIM Android system account back to work to see the contacts in the dialer. After I unchecked and checked the EPIM system account checkbox, and EPIM recreated the account back, everything is now working like before.
Hi paulvp, read just that...
paulvp
Post by paulvp »
Thanks for that :). I did read that post but wasn't sure about how to install something on my phone that didn't come direct from the Play Store. I'm sure I can figure out if I try but thought the path of least resistance might just be to get the admins to activate my pro version, since I still have the order number.
Cheers
Paul.
Laurent C.
paulvp wrote: Sun Sep 24, 2023 10:08 pm Thanks for that :). I did read that post but wasn't sure about how to install something on my phone that didn't come direct from the Play Store. I'm sure I can figure out if I try but thought the path of least resistance might just be to get the admins to activate my pro version, since I still have the order number.
Cheers
Paul.
No, just do it, accept the installation from unknown sources (not unknown = EPIM), and install latest version just after... Rgds
paulvp
Post by paulvp »
OK, just tried that but I get an error message: "App not installed as package appears to be invalid".
Guess I'll just wait for the admins, which is fine.
Laurent C.
The admins will ask the same - believe me : it was exactly my past issue - just uninstall the version you have on Android + install the AEPIM 5.8.7 + install the Google Play version - Regards.
paulvp
Post by paulvp »
OK, done. Seems to have worked so thanks very much :).
Laurent C.
paulvp wrote: Mon Sep 25, 2023 10:26 am OK, done. Seems to have worked so thanks very much :).
You're welcome 8)
lorymax
Been thanked: 7 times
Post by lorymax »
Update. The problem is always the same even on Android 14 (Xiaomi Redmi Note 12) and even in this case the solution I wrote above works.
Laurent C.
lorymax wrote: Sat Feb 03, 2024 10:04 pm Update. The problem is always the same even on Android 14 (Xiaomi Redmi Note 12) and even in this case the solution I wrote above works.
Yes, it's always the same issue on Android 14 — and strangely it's also always the old AEPIM 5.8.7 that needs to be installed 1st :o
Dierk
Has thanked: 35 times
Been thanked: 9 times
Post by Dierk »
This process does indeed work (or it did here...) - of course, then you need to Re-sync with desktop (if appropriate)
uninstall AEPIM 6.0.5
download AEPIM 5.8.7 via this link: https://www.essentialpim.com/download/o ... _5.8.7.apk
install the downloaded AEPIM 5.8.7
start AEPIM 5.8.7. Just a few seconds later it automatically found my license and Pro-featuers became available
update to AEPIM 6.0.5 and Pro-features remained available.
Laurent C.
:arrow: Nice to give us back the full detailed process to reactivate pro-license
