Long-time WEPIM & AEPIM user.
For years I've successfully synced data by wifi to/from multiple phones and tablets.
Just installed AEPIM on a Samsung S9, OS Android 10.
Only on the S9, address, email and some phone numbers are missing. This data is present at WEPIM and on other devices.
WEPIM Pro 11.0.4
AEPIM 6.0.2 (on all devices).
Any thoughts?
Contacts Sync missing address, email, phone
- PeCe
- Has thanked: 101 times
- Been thanked: 329 times
Re: Contacts Sync missing address, email, phone
This is a problem of AEPIM 6.0.2.
It was mentioned before in this topic; https://www.essentialpim.com/forum/view ... hp?t=37194
So far no reply from development and since it has not been corrected I remain using 6.0RC1 (that can be downloaded from this forum).
In 6.0RC1 the sync is correct, 6.0.2 has problems.
I'm using AEPIM 6.0.2. I missed data on syncronization. How can i find 6.0RC1 ? i use actually AEPIM 6.0.2 for calendar and contacts. Best
Andrea Valeri MD
Andrea Valeri MD
- Has thanked: 1419 times
This is fixed in the 6.0.5 version, please update.
- Has thanked: 1 time
Update where/how?
Just checked GooglePlay and they are still flogging v6.0.2.
Can anyone point to an alternate source for this newer version? Has it been officially released or is it still in beta testing?
- Has thanked: 5 times
- Been thanked: 2 times
My S9 auto-updated to 6.0.5 on Sept 14th.
No change re missing contact info - see my original post in this thread.
More detail - only fields shown are:
First, middle & last names
Company
Home Phone
Membership (Group)
Notes
I did run a Sync, just in case. No change.
Then I re-started the phone, and re-synched.
After that, it added 3 or 4 other fields _only to self and spouse_ ..... weird.
Company
Home Phone
Membership (Group)
Notes
Peter
Please check how it's going to work with a newly created test contact. Will all of its fields get synchronized?
All fields in the test contact were synched, with errors noted below:
These fields correctly synced:
First & last names
Company
Membership (Group)
Home (Address)
Notes
These fields incorrectly synced:
WEPIM > AEPIM
Mobile > Home Phone
Home Phone > Home*
Email > Mobile Email*
* these are the same fields that were added to self and spouse (see above). They didn't exist before the sync.
I also synched to my tablet (KTE K87CA, Android 10, AEPIM 6.0.5).
That sync was successful, no incorrect fields.
As noted above, it's only on the S9 that I have problems. My tablet syncs fine on 6.0.2 & and 6.0.5
First & last names
Company
Membership (Group)
Home (Address)
Notes
WEPIM > AEPIM
Mobile > Home Phone
Home Phone > Home*
Peter
We are unable to reproduce this. Please forward us the log file after synchronization with your phone. The log can be found here: Tools->Options->Synchronization, Browse... and its filename should start with "AndroidSync". Also mention one of the contact's name with the problem.
