Moving in the "All Fields" section of the Contact List
jsc
Been thanked: 11 times
Post by jsc »
Is there a hidden key combination to move to the next/previous record (ie, up or down in the list) while editing in the "All fields" window in the Contacts editor?? Looks like I have to close the window then pick another record to edit.
I'm not talking about editing in the list window, but rather the Contacts editor when you double-click on a record.
If not, it would be a nice addition...
Re: Moving in the "All Fields" section of the Contact List
There's no such an option, unfortunately. Although, why not use the lower section of the main window for editing fields? In this case you will not need to open separate contacts editing windows.
jsc
Post by jsc »
Because the "lower section of the main window" does not show fields that have no data in them. Also, when adding a new contact, the main editting window is activated, and it would be nice to navigate to other records when in that view.
And while I'm at it, it would be nice to have a "duplicate record" menu selection. Yes, I can copy and paste, but a command would make it quicker.
Let's see if other users need this feature.
