I have two databases: the first with only one calendar + task, the second with two calendars.
How can I merge them into one database?
I tried with the import function of epim pro 11.0.4 but the imported calendars are inserted into the one already present.
I would like to have three separate calendars.
It's possible?
Thank you.
Multiple calendar import
Re: Multiple calendar import
Rename the calendar that has identical name with the one in another database and use EPIM Synchronizer: https://www.essentialpim.com/features/f ... nchronizer
Hope it helps. Thanks!
Yes, that's also an option. Thanks!
