I have noticed that tag explorer doesn't show all items that have a specific tag. Some appointments for example are not listed, although they have the selected tag assigned to them.
Is this an issue or am I doing something wrong?
Thanks in advance.
Kind regards.
tags explorer doesn't show everything
Re: tags explorer doesn't show everything
Please describe the problem in as much details as possible (preferably with a list of steps and couple of screenshots) so that we could reproduce it on our side. Thanks!
Trying to reproduce but takes some time because I can't find the logic.
While trying to reproduce I have found something that might be partly causing weird behavior.
Create tag "test" and assign it to 1 item.
Create tag "testing" and assign it to 2 items.
For tag "test" the tag explorer
- shows (1) suffix: correct
- but displays 3 items: wrong
Confirm this problem, will fix it. Thanks.
Another weird thing; to reproduce:
- Create appointment "tagtest" with a new tag "tagissue". Set 20 recurrences in same day of the week.
- in calendar a search for appointments with strings "tagtest" or "tagissue" Will show 20 items in an orderly fashion.
- in tag explorer suffix (1) Will be shown: should be 20.
- tag explorer will display 20 appointments but not in an orderly fashion: like dates and appointments are being mixed up
Kind regards
Kind regards
Thanks, will fix this one, as well.
Hi admin,
However there is still an issue with multi-day items.
To reproduce please repeat the steps quoted above
Then add a new whole day appointment, with start and end days for example 25 days apart.
Tag explorer now shows dates and appointments in an weird, unorderly fashion again.
Remove the new whole day appointment, with start and end days for example 25 days apart and again, tag explorer displays everything in an orderly fasion.
Thanks for fixing the issue above - can not be reproduced in 6.0.13kdgdr wrote: ↑Wed Aug 03, 2022 4:44 pm Another weird thing; to reproduce:
So far, so good ...kdgdr wrote: ↑Wed Aug 03, 2022 4:44 pm - Create appointment "tagtest" with a new tag "tagissue". Set 20 recurrences in same day of the week.
We are unable to reproduce the issue you are facing. In order to better understand and investigate the problem, could you please create a short video demonstrating the steps you are taking when encountering the issue?
