​regenerating tasks with due dates instead of only start dates
kdgdr
Has thanked: 9 times
Been thanked: 18 times
Post by kdgdr »
Currently for tasks, regenerate ... after completion only uses start date of tasks. Please consider changing so that due date of new task (after completion) behaves like it does for example with repeating tasks every ... days.
Thanks in advance.
Kind regards.
Re: ​regenerating tasks with due dates instead of only start dates
Not quite sure what you mean. Please elaborate a bit more about the suggestion and better include a concrete example. Thanks.
kdgdr
Post by kdgdr »
Same as this topic in WEPIM forum:
https://www.essentialpim.com/forum/view ... hp?t=37023
As you can read there, I should not have posted it in WEPIM forum because problem only exists in AEPIM, sorry.
Kind regards.
Understood, thanks for the update.
kdgdr
Post by kdgdr »
Hi, works great in v6.0.5, thanks for fixing!
