What is the data limit on Essential PIM
While I am assuming that it unlimited I am curious as to what the limits for the software is as I have around 1600 notes in the software right now and have barely scratched the surface. I need to know if the software will be able to keep up if I have say about 10000 notes or more thanks!
- Has thanked: 1412 times
Re: What is the data limit on Essential PIM
10K notes shouldn't be a problem.
In version 11.0 free, I have a Note file with 8.168 KB, and I can't write anithing more, because the new version eliminates all I add in Notes!
Is it bug in the version, or it is a feature in the version??
Please, say it to me.
Seems like a bug. How do we reproduce it? If possible, please copy-paste that note into the new DB and forward to us.
I use EssentialPIM Portable free vr. 11.0.
I have 431 contacts, 3054 appointments, the Note file yet has 8.168 KB (Hugo.EPIM).
In one contact field, in Notes (under "Reggiani Condomínios"), I have this 2 lines correctly inserted (without ***):
Gerente: Angela <atendimento01@admreggiani.com.br>
Karina: 94513-2972, 97680-7302
If I insert 4 more lines, like this (without ***)
Atual, desde 2018:
gerente do Ravel: Angela Cristina (bem gorda) - <gerencia01@admreggiani.com.br> - 5052-9767; 94513-2972 (WhatsApp)
(cel. e WhatsApp - Karina, assistente) - 97680-7302 (cel. e Whatsapp da Angela)
assistente: Karina Cruz <atendimento01@admreggiani.com.br> (era Aline, Paola); WhatsApp: (11) 94513-2972
Then, the Note field trunks all data, and only this remains, in all field Notes (without ***):
11) 94513-2972
I don't know how to forward to you the DB. Can you told me, please?
Thanks, Hugo
Atual, desde 2018:
11) 94513-2972
Thanks, Hugo
Hi, Admin.
It is possible that I made a discovery. It does look like a bug.
When in the Notes I write all the text without parenthesis signs _(_ these signs _)_, I can save it without any problems. But when I use parenthesis signs, when I close EssentialPIM and when I reopen it, the Notes text is truncated!!!
Please get the final release version (https://www.essentialpim.com/download-free), the bug should be fixed in it. Thanks!
